How to save custom colors?
How do you save a custom color under the surfaces tab?  Please see the attached screenshot.  If I click "Add to custom colors" the green color I have selected will replace the pink color in the box in the upper left of the "Custom Colors" section.  How to do I get it to replace the white color in the highlighted box?
  • Update
    I was in incorrect.  "Add to custom colors" does save the color in the highlighted box.  However, I think my confusion was due to another issue.  When I try and adjust the color using the numbers, either entering a number or using the up/down arrows, the highlight around the color box disappears.  This will make the new color overrite one of the preexisting custom colors.  Initially, this appears to be the first color (upper left), but if other attempts to save other colors are made it seems to overrite colors randomly.  Is there a way to save a color entered with the numbers boxes to custom colors?
  • FSMCDesignsFSMCDesigns Posts: 12,844
    If you are talking about in that color pallette, then just drag the existing color to one of the small boxes to it's left.
  • cgidesigncgidesign Posts: 442
    edited February 2022
    Yea, as FSMCDesigns wrote: Drag and drop smiley
    609 x 433 - 59K
    Post edited by cgidesign on
  • Thank you both for the response!
  • RandomRandom Posts: 224
    Finally, after all these years of being frustrated with losing custom colors. Drag and drop. Oii.
  • And best is, it works in any software that uses this windows standard color control.
