Why did DAZ default install box pop up?
daveso
I have DIM and DAZ Studio installed on my system for quite a long time and have been using it. I did have some hard drive problems a week or so ago, and now this box is popping up in DIM wanting me to install even DAZ Studio again.
Troubling to say the least, but I just installed a product, it appeared to go into DS, but when I tried to use it a box popped up staing the files could not be found.
I think my installation is caput?
Post edited by daveso on
oh ..just realized DIM is not seeing most of my installed products within DS ..only shows 34 installed. Looks like time to start over from scratch?
OR IS MY CURRENT INSTALLATION REPAIRABLE?
It is the manifest files that teels DIM what is installed.
Find where they are and if DIM points to the right place.
thanks -yes, I have my DS and DIM installed to D drive. For whatever reason, DIM now show everything to C drive. I'll change all of the locations and see what happens.
I just went to install the current beta to try it alongside 4.15... First time I tried a beta so I was a little clueless, but after going through the process in DIM of un-hiding the "Public Build" stuff, selecting them in "Ready to Install" and hitting go, for whatever reason, a box/list exactly like the one you pictured came up saying these assets were necessary, etc. I thought, ok, I'm not familiar with this process so I hit OK... Then DIM installed the current General Release 4.16....3 or whatever, over my 4.15, and didn't install the beta at all. Not sure if it's a related problem at all, it just caght my eye when your screenshot showed the exact same odd looking list I had never seen before, and it was indeed intending on doing the normal update I was putting off.
Looking again in Ready to Download, all the Beta stuff was still sitting there, so I did then successfully install the beta, too. Both seem to be working fine on a little older i7 with an 8GB 2060s. Haven't gotten around to finding out where I stand with Ghost Lights which was one of my main concerns with any updating...
now DS itself has nothing in the smart content pane ven though the content in manager is pointing to correct location. strange things going on.
Try Content DB Maintenance > Re-import metadata
Redacted
and yet I was able to port my content across fairly easily, though I hadn't lost the HD and did have a back up of the database. The only snag was that the system was fussy about where I puit the backed-up database files.
Redacted
The database isn't user-editable, or even user-accessible, everything happens behind the scenes. It's like settings, so I guess that is whjy it defaults to that location. It's also fussy about folder permissions.
