Carrara no longer runs. Such a shame.
2»
  • StezzaStezza Posts: 8,789
    mykyl said:
    Stezza said:
    just wondering @mykyl
    if you open up notepad then save as wintab32.dll and put that empty file in the Carrara folder will Carrara startup ?
    Oh it pops up an error dialog saying there is an error that the file is either not designed to run on windows or contains an error. However once you close that dialog then Carrara runs. Wee bit annoying but at least it still works.
    I had another wacom wintab32.dll that was smaller than the one I listed above and it did not work. Carrara still closed using that one.
    The driver version I got the wintab32.dll from is WacomTablet_6.3.40-2. Using this means you get no errors.
    thanks for testing that... another workaround of sorts yes
  • HeadwaxHeadwax Posts: 10,426
    Stezza said:
    lol @headwax
    a bat file is an old MSDos file that executes a set of commands.. when you double click it it does it's thing.. it's been 40 years since I wrote one and I can't remember how to do it now !!
    heh, last time I wrote one I was a batchelor
