Morph Loader
I'm trying to save a character but no matter how I save it it ends up in the Morphs Loader file.  How can I fix this?
  • GordigGordig Posts: 10,678
    edited February 2022
    In the Morph Loader dialog, expand the morph you've loaded, then right-click on the Property Group option to add it to an existing category or click Create to make your own.
    473 x 450 - 23K
    Post edited by Gordig on
  • Thank you!
    If you want to move morphs that you've already created, click on the cog icon at the top-right of the morph slider, select Parameter Settings, and change the Path.
  • The original blender looks to be gone.  Yah it's in DS as a morph.  I've tried changing the path in the parameter setting but it won't save that way.
    I should have mentioned that you'll have to re-save the morph in order for it to stay that way. I don't remember if Save Modified Assets works, or if you have to actually re-save the morph itself.
  • Thank you!  I got it working right.
  • HaruchaiHaruchai Posts: 2,040
    Also, if you want to do it retroactively you can edit the morph file directly. Open the dsf (morph in the data folder) in a text editor and look for the 'region' or 'group' area. This tells Studio where to show the morph. You can edit this and then save it without having to make a copy.
    Note, you may have to uncompress the file and then add the dsf extension back to it after editing.
    I spent a couple of hours one weekend editing morphs and now my Genesis 8 Female loads like this. All random morphs that were loaded to the base list are now organised under sub catergories of a 'Morphs' folder :)
    It may not be quicker for a single morph but if you want to move a folders worth it means you can batch edit in Notepad++ instead of having to do each morph individually.
    812 x 843 - 70K
    397 x 600 - 52K
    Post edited by Haruchai on
