DAZ Studio (Not Responding)
I am having a problem with loading a saved scene. I go back to load after working on others, and I get the DAZ Studio (Not Responding). Is there any settings I can Change? This only started a few weeks ago, but is steadily getting worse.
but does it eventually load, or no? and have you let it sit for a while, and let it take time to load, or are you clicking the program, hoping it respondes?
i'm noticing the more stuff i do, the higher loading times. i can have a single object on scene, but if i've added a dforce simulation, and save, it'll then take more time to load.
Sometimes it does NOT load. It is the reading process, the close program window will come up. I was just wondering if there was a way I can get it to stop.
Thanks. I wish it was that easy. I have 64 gbs of DDR4ramm. Even just changed over to SSD drive a couple of months ago. I set my 2070 gpu to go max yesterday, hoping it would do something . No avail... Sent a ticket in to tch help, as it seems it is a Daz problem. I have 2 different ones, and they both act this way.
"Not responding" just means that the program is busy and hasn't answered in time the calls made by the OS, it doesn't mean the program has crashed. Just give it time to see if it completes what it is doing.
If you try clicking something, you will get the OS box asking if you want to close the program, but that still doesn't mean that the program has crashed.
The log may give some clue to why it is taking so long, usually there are conflicting morphs and missing assets for the figures, which may even cause the base figure to take an hour to load.
This is true. I just never had this problem till a few weeks ago... And yes. All my characters are customs, nothing straight off Daz...
It doesn't need much, one character added to DS library that has problems, could increase the time xx minutes
