aged-for-v4-m4 is not functioning at all
No change to the face when icon in library has been clicked, no slider added in parameters
https://www.daz3d.com/aged-for-v4-m4
  • NorthOf45NorthOf45 Posts: 5,733
    edited January 2022
    Did you select the "Generate ExP files" box in Power Loader the first time you load M4 (or V4) after installing Aged? It only needs to be done once, but is essential.
    Post edited by NorthOf45 on
  • LeanaLeana Posts: 12,909
    The face is not supposed to change when you use the "INJ Aged M4" icon. That icon is meant to make the dials usable if you didn't activate them when loading M4.
    If you want the face to change, you have to set the face morph to 1.
  • VicSVicS Posts: 1,273
    yes it is checked North, the same thing happens with M4 elite ethnic faces (I imagine the same wil lhappen with V4 as well)-no change on face no new slider in parameters.
    it has the warning icon where Witch and Warlock do not.
    I don't know if it means anything but these boxes in M4 loader are unchecked
    2785 x 1838 - 2M
    1264 x 1442 - 117K
  • Please stop making new threads on essentially the same topic, especially as you have been told that the INJ poses for shapes (rather than characters) are not meant to apply the shape.
