Boolean in Carrara or Hexagon or am I a fool?
13»
  • StorytellerStoryteller Posts: 80
    mostly solid modeler, solidworks, autocad, etc, however, here is a list and some links. CSG is Booleans, just, sensible. Adding CSG trees to carrara is a no brainer. Adding CSG trees to Hex ..and an intelligent solid to polymesh algorythm' is slightly harder.
    For starters, there is DeleD3d, it is open source and has a great CSG implementation. Ive not noticed lot of the traditional artifacts in polymesh conversion.
    http://www.delgine.com/
    here is a pdf on csg bsp
    https://www.andrew.cmu.edu/user/jackiey/resources/CSG/CSG_report.pdf
    and here is a list of software from wikipedia
    https://en.wikipedia.org/wiki/Constructive_solid_geometry
    Applications with CSG support[edit]
    Generic modelling languages and software[edit]
    HyperFun
    PLaSM - Programming Language of Solid Modeling
    Ray-tracing and particle transport[edit]
    PhotoRealistic RenderMan
    POV-Ray
    CAD[edit]
    BRL-CAD
    FreeCAD
    OpenSCAD
    SolidWorks mechanical CAD suite
    Vectorworks
    Gaming[edit]
    GtkRadiant
    UnrealEd
    Valve Hammer Editor
    Roblox
    Others[edit]
    3Delight
    Blender (provides meta objects)
    Clara.io
    Feature Manipulation Engine
    article from leadwerks (a game engine)
    http://www.leadwerks.com/files/csg.pdf
    and for grandpa, here is a page on CSG for POV-Ray
    http://www.f-lohmueller.de/pov_tut/csg/povcsg1e.htm
    anyway, I think seeing CSG in Carrara or Bryce would be a thing, maybe in some form it is already there.. I mean Hex already uses dynamic geometry stacks...
    Perhaps its just the algorithm used in some of the software Ive used that is so nice, but I would never confuse CSG with polygon booleans.
  • cdordonicdordoni Posts: 584
    If you have to use booleans and are running into difficulties, its possible to repair the objects in another application and bring them back in for additional work.
    I used Hexagon and the free version of Netfabb to build some models for 3d printing. After a few boolean operations, when Hex would refuse to do any more with it, I would export the model and repair it in Nefabb, then bring it back in to Hexagon to do more booleans. I usually had to repeat this process many times to finish a model.
  • RoygeeRoygee Posts: 2,247
    Thanks for the information - very interesting. I've downloaded Deled to give it a try and see whether it can give a clean mesh:)
  • Design AcrobatDesign Acrobat Posts: 459
    edited December 2014
    I might be incorrect but I think you have to purchase the pro version of DeleD to get some of the Boolean functions like subtract - Otherwise you just get slices ($75 I think is the price). There is a demo though. Pretty sure it triangulates, so unless you have a program that will remesh into quads like Zbrush or 3Dcoat - you're stuck with triangles.
    Edit: Added some snaps to show the differences of Boolean in 3DCoat and Carrara and also what it looks like in quads after being remeshed in Zbrush.
    Top is booleaned in 3dCoat
    Center is remeshed in Zbrush
    Bottom is booleaned in Carrara with remeshed results similar to the image shown above.
    861 x 721 - 270K
    739 x 675 - 127K
    823 x 716 - 147K
    Post edited by Design Acrobat on
    I did give DeleD a spin ( it does have the normal Boolean functions, but not as many options as Hexagon) and not at all impressed. Don't see anything that couldn't be done better in any other application. Took a look at the example files and they aren't up to much. I certainly wouldn't fork over any money for it. Of the Daz products, Bryce gives the best results, but then Boolean is it's only modeling method. I personally find modeling in Bryce difficult because of all the intersecting lines - you really have to have your whits about you :)
    If I absolutely have to do a Boolean operation, I would do it either in Hexagon and remesh in Blender, or just do it in Blender. What I like about Blender and Bryce is that Boolean is non-destructive until you finally commit, so you can keep adjusting to see the result.
    Post edited by Roygee on
