Error 404(10)
lorddayradon
Post edited by lorddayradon on
lorddayradon
The script is looking for a G8M, and it doesn't recognize an 8.1 as such. There's also the issue that 8.1 includes a new UV set that splits the torso surface into head and body surfaces. Most content is fully compatible between 8 and 8.1, by which I mean that 8.1 is fully compatible with most products for 8. What you could do is apply the attachment to G8, then run the script, then after the materials are copied, re-fit the attachment to 8.1. If you really want to use Kayden's skin, you can follow the method I outline in this tutorial to load Kayden's materials on a G8M.
