• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > 3ds Max Discussion
How faster is 3ds Max than Daz studio for scene making and rendering?
dan_thomasdan_thomas Posts: 107
January 2022 in 3ds Max Discussion
This may sound stupid but according to my observation, it seemed that one could create and render scenes with 3ds Max a lot faster than with Daz studio. I would like to make sure with experts if this is true or not.
I have about 6 month experience in scene creation and rendering with Daz studio as a hobby. I could currently create a satisfied render for about 5-6 hours - obviously too slow. So I am looking for an alternative software for scene creation and rendering. And I found that many artists of comics or VN could produce about 80-120 good renders per month with Daz studio but 300-500 renders per month with 3ds Max. Of course, I don't know much about their setup or workflow. So my question is: How faster is 3ds Max for scene making and rendering than Daz studio? And what factors make it faster? Thanks.
    January 2022
    I can set up a scene and render it in Iray in less than 10 minutes, if doing that for 4 hours per day, 20 days a month = 480 renders
  • Richard HaseltineRichard Haseltine Posts: 109,541
    January 2022
    What do you mean? They are markedly different tools, using 3D Studio for the sort of task Daz Studio does well would be gross overkill - and quite possibly not that efficient as you'd have to work through all the UI aspects thata re there for the things 3DS does that DS doesn't. On the other hand, trying to use DS along for things that are 3DS specialities such as modelling would be an exercise in frustration. You don't give any meaningful description of what you are doing, without that no meaningful answer is possible.
  • tysoe_c1fec8e832tysoe_c1fec8e832 Posts: 8
    January 2022
    I thought the same thing at first. Unfortunately the Daz2Max bridge is broken and severely limited. Firstly the materials tend to come out borked with every body texture except the face black. That's quite a lot of work to fix with 10+ materials. Then you have to rework the materials because the defaults are pretty basic, just diffuse color and monochrome bump because the bridge is essentially a .FBX bridge and is limited to what FBX supports. On top of that, I noticed that a lot of the vertex assignments are not accurate, so you often end up with bad distortions, with skinny knees that stick out. Then you have the problem that you can only export a character in a default Daz pose, otherwise the CAT rig the bridge creates is broken. No way to get Daz poses in accurately.
    It's very disappointing. I ended up looking at blender instead.There is a third party exporter for Daz called Diffeomorphic which is amazing. Just wish blender was as intuitive and easy to use as Max, Arnold also renders significantly faster.
    Unless you have a lot of time and patience on your hands, you are probably better off sticking to Daz Studion. The biggest benefit of being able to export from Daz is the ability to create and light scenery around your characters. But that is a lot of work with the current state of the Max exporter. A real shame.
  • dan_thomasdan_thomas Posts: 107
    January 2022
    Thanks for your answers. They are valuable information. I understand your points. Yes, the conversion between Daz and Max is additional problem. But I can use Max without the conversion by buying assets made for Max. Even in that case, I wonder what made scene-creating and rendering with Max faster than with Daz.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
