How do I add an opacity cut out?
Torkuda
Making a new surface, how do I add an opacity cutout?
Torkuda
Add the property (you need to selct the surface and apply the iray Uber Base preset) or create a map (black for the cut out areas, white for the opaque, following the model's UVs)?
I wanted to give this some examples. I always learn better from pictures. I created the cutout in Photoshop.
Thanks . But what do you do if the cut out opacity option is not there? How do you enable it then?
