daz turning to grey missing geometry boxes when moving or rotating
VicS
It's the grey missing geometry boxes, happens in texture or filament, it goes right back to normal view when rotate or move is finished.
I've restarted used new file, will I have to reinstall daz or what could it be?
thanks
It was when draw mode is in bounding box mode, weird it never happened before.
You may have hit ctrl 2 by mistake, that puts the Viewport in Solid Bounding Box mode.
Sorry, I misunderstood. If it is omnyl when adjusting poses then you have the Manipulation Drawstyle (in Draw Settings) set to Boundign Box, set it to Use Current (Off) and it will use the drawstyle currently in use while posing
Ok thanks Richard
