D-forms error
SertorialSertorial Posts: 962
Is there some reason why D-forms don't work with Genesis 2?
If I select a region and try to create a new D-form I get the Selection Error :
"This action requires an item within the scene, with geometry, to be selected" (see screenshot)
It works fine, say with a plane primitive, so why not with Genesis 2?
  • WilmapWilmap Posts: 2,917
    edited December 2014
    I think you have to select the whole figure and apply the DForm to that. Then move the DForm to the part you want to change.
    Post edited by Wilmap on
  • SertorialSertorial Posts: 962
    No, it's supposed to work on just a region of a figure too. See this video (from about 2 minutes)
    https://www.youtube.com/watch?v=GoGqfV8E7Co
    Anyway, it works fine on V4. You can select a region only and apply a d-form to it.
    So why not G2?
    Post edited by Sertorial on
    Probably because G2F is a triax figure and Gen4 figures are legacy.
    what's that in English? ;)
    (remember this is the beginner's forum)
  • Richard HaseltineRichard Haseltine Posts: 109,462
    For DS4 using Genesis or any other new figure you need to have the figure node selected when creating the DForm - the newer figures don't assign bits of the geometry to bones the way the older, Poser/Legacy rigging system does.
    But that means the d-form will affect the whole figure! There must be a way to just shape one region?
    I thought Genesis was supposed to be a more advanced figure than V4? Less control = less advanced (in my book)
    Adjusting the field size and location should help, if not you can use the Node Weight Map Brush tool to assign a weight map to the DForm and control what is affected through that rather than the field. But this is a drawback of the TriAx system, yes.
    Ok, thanks
