Clothing with mis-named nodes - any way to fix this?
Some time ago, I bought The Bride Wedding Gown for Genesis 8 Female(s)
Some time later, I discovered a problem with it: the skirt doesn't pose when you pose the figure's legs.
I presume this is because every node below the pelvis has its name and lable prefixed with "DRESS" (E.g. "DRESS Left Thigh Bend" rather than "Left Thigh Bend").
Is there any way to fix this myself?  (Renaming in the scene doesn't help - presumably because that only changes the lable rather than the actual name of the node).
  • barbultbarbult Posts: 26,390
    That is not an error. The dress was intentionally designed to NOT follow the legs. You are supposed to use the skirt bones to pose the skirt manually. Big flowy skirts can look ridiculous if they automatically follow the leg movement.
  • Ah, ok.
