elongating genesis neck
Is there a way to elongate Genesis neck?
Or is there a set with  controls for elongating not only the neck but limbs and torso etc?
  • docbotherdocbother Posts: 108
    Not a step by step. and this is just quick and dirty, but the gist is: Select the neck then increase the scaling Y-value. You will need to change the posing or parameter panel preferences to "show hidden properties" so you can see the Y-scale.
    There is a problem with genesis 1. Scaling the neck also causes the head to also scale in the Y direction. That is just wrong. To fix this you can the select the head then scale it back down and the neck remains scaled.
  • VicSVicS Posts: 1,273
    Where would I right click, with neck selected I right click on transforms, scale or any other possibility, none unhide scale in x y or z, which specific tab must I click on to unhide x, y and z transforms for the neck? thanks
  • SpaciousSpacious Posts: 481
    edited January 2022
    There is a hamburger menu in the top left corner of the Parameters pane, just above the tab that will allow you to show hidden properties.
    (Edited becuse I wrote right when I meant left.)
    Post edited by Spacious on
  • Spacious said:
    There is a hamburger menu in the top right corner of the Parameters pane, just above the tab that will allow you to show hidden properties.
    Hamburger/lined button, or right-click the pane's tab.
    Were trying to get the hidden transforms x y z to show, the only place I find unhide seleceted properties is when right click on neck-hidden-that's the closest thing I canfind, clicked on everything else in hamburger menu and pane's tab, if you have a way that does the trick can you take a screen shot or let me know how to also, thanks
    Here;
    504 x 533 - 41K
    Ahh preferences!
