What does the V4 Skirts option in Autofit do?
ScavengerScavenger Posts: 2,674
In autofit, there's the option of V4 or V4 Skirts.
I can't see a difference when I've tried it on skirts or dresses, (which is a shame because those don't seem to sutofit well).
What's the differernce if any between the two?
    Where are you seeing V4 Skirts as an option? I am only seeing Victoria 4 in the 'What figure was this originally designed for' drop down.
    Do you mean in the 'What type of item is it' dropdown? Skirt has always been there as far as I remember.
    What problem are you having with V4 skirts? Is it just the posing handles that don't work? Can you give an example of a skirt you are having trouble with, and I'll see if I have it?
  • StargazeyStargazey Posts: 272
    Do you have the Sickle Rigging and Morphing System? - I think it may have something to do with that!
    Nope! There's actually a V4 Skirts option on the G2F autofit that comes with Victoria 4 for Genesis 2 Female! Mallenlane just did some great work there.
    It uses a differently shaped clone so that there's not such a bad triangular divot in the crotch area when you autofit V4 skirts to G2F. Very nice feature.
  • ScavengerScavenger Posts: 2,674
    Yeah..that's the problem I'm getting. Didn't seem to better in either mode. I ultimately punted and decided that the poses would hide the area and try to fix it next time I enocounter it.
