DCG - Ground Control Update
rk66rk66 Posts: 449
Hi,
a new update for Ground Control is online:
http://digitalcarversguild.com/plugin.php?ProductId=7
rk.
  • RoygeeRoygee Posts: 2,247
    Hi there :)
    Thanks for that info.- I am keen to buy Ground Control as well as Terraintools; they come highly recommended.
    I prefer to test before buying, so downloaded for evaluation, but regardless of what data sets, formats and settings I use, I get the same results - see attached pic.
    Is this how the evaluation works, or is there something I'm missing?
    1600 x 900 - 243K
  • Eric WinemillerEric Winemiller Posts: 84
    Hi Roygee,
    That is how the demo mode works. It zeros out the elevation in a checkboard pattern.
    Regards,
    Thank you - it would be great if you had a demo version which gave a true reflection of the capabilities, so i could compare the results with what I'm currently getting going via 3Dem and Bryce.
    But I guess I'll buy it anyway - it has such a good reputation :)
