Help..........what is causing this? Everything coming up white in viewport. SOLVED
Aave NainenAave Nainen Posts: 1,108
Anyone know what is causing this? After installing 4.7 this is my viewport, so I un-installed Studio and re-installed 4.6 but still getting this in viewport. The textures render properly so I can't figure out what's up. I cleared the cache, shut down my computer, checked to see if any problems were showing on my video card (NVidia Quadro FX5600) etc. but now I've run out of ideas........
I should clarify perhaps I had been using 4.7 for a few hours before this happened when I started working on a new scene.
Post edited by Aave Nainen on
  • LyonessLyoness Posts: 1,637
    I have this happen occasionally.
    I have tried many different things and usually it's best if I close DS.
    then open the scene again. it seems that the cache gets overwhelmed.
    on a bad day.... after opening, I have to reapply the textures..
    It is probably just the display option has been changed from texture shaded to smooth shaded. The display option is a little sphere icon and will be in one of the upper corners of the viewport.
  • Aave NainenAave Nainen Posts: 1,108
    OMG! I can't believe I did that..........Jestmart.........you are right! Now if only I could remember switching to smooth shaded :) :red:
  • Richard HaseltineRichard Haseltine Posts: 108,488
    Pressing ctrl plus a number key also switches display mode, I suspect that's what happened (maybe you missed when aiming fro ctrl-y to redo a command).
