Please Daz Team fix this (Upper Rig Face)
As you see in pictures, Genesis 8 Basic MaleGenesis 8 Basic Female and Genesis 8 Male Dev Load has the Upper Face Rig visible, but the Genesis 8 Female Dev Load for some reason or mistake of someone in your team, has marked to hidden.
I figured this out because my script doesn't work on any character that was created using Genesis 8 Female Dev Load as a reference, as the script fetches the Upper Face Rig.
  • felisfelis Posts: 5,902
    You have to raise a ticket.
    Daz people don't generally look in the forums.
    Stragely the hidden status is something that cannot be changed by the user, tried to get into the bottom of it, but found no way to get them unhidden
    https://www.daz3d.com/forums/discussion/453831/hide-in-scene-view-s
  • Workaround: open the Scene pane option menu, the lined/hamburger button in the top corner or right-click the tab, and enable Show>Show Hidden Nodes
    Fix, pending an official update: use the workaround as above, then activate the Joint Editor tool and open the Tool settings pane. Select each bone in turn (it works only on the primary selection so ytou can't just seelct all) and uncheck Hide in Scene Views in the Atributes secrtion of the pane.
    But yes, please do open a tickert about this.
