The best way to change genesis 8.1 skin color ? (darker)
Hi all,
I'm looking for a the "best" way to change genesis 8.1 skin color. I would like to color the skin more darker.
I tried the https://www.daz3d.com/ultimate-pbrskin-manager ; the result is not what I would expected, it seems so fake ... I don't want to do an Orc skin lol.
Maybe someoneelse can share his way of doing darker skin color on his genesis 8.1 skin.
Thanks in advance :)
  • charlescharles Posts: 866
    edited January 2022
    Translucency Weight in surface shaders. The higher the number the darker, the lower the lighter. If that's not enough change the Translucencey color itself darker.
    Post edited by charles on
  • HLEET_3DHLEET_3D Posts: 172
    edited January 2022
    Thank you @charles !
    It works !
    I understand now why there are no skin darker plugin for 8.1, it's so easy to make it in surface tab (if you know where to look at :D)
    Post edited by HLEET_3D on
  • ramon73ramon73 Posts: 96
    I often use the Anakku model that comes with 4 different tan layers that can be applied onto most models. Looks better than messing with translucency. https://www.daz3d.com/anakku-for-genesis-8-female
  • PadonePadone Posts: 4,335
    To be precise. Translucency interacts both with diffuse and volume, so the more translucency the less diffuse and the more volume. If you use a white or pale diffuse and volume then yes, you can control with translucency. Otherwise the three of them contribute. That's how skin works.
    diffuse > translucency > volume
    Hi @Padone
    Are you talking about "Diffuse Roughness" ?
    Could you explain what this slider do, when I put it at max, I don't see much of difference. (Diffuse button is Enable).
    I don't see the "volume" slider, maybe there's another name for this ?
    edited January 2022
    Here is a portion of my render project to darker genesis 8.1 skin.
    I used this figure : https://www.daz3d.com/vyk-marty-for-victoria-81
    I'm quite happy with the result (thanks to @charles explanation).
    The problem I encountered is that the "map" (?) is not the same for the face and the body.
    So I had to use a different color for the Translucency color for each part. If I don't do this, the face will turn way darker than the rest of the body.
    @Padone : Maybe you have an idea of which slider I should use in order to get a more even color for body and face ?
    Thanks in advance
    3000 x 3000 - 5M
  • cgidesigncgidesign Posts: 442
    edited January 2022
    An alternate way to change base skin color is actually the "base color" (as the others said, translucency is tricky to master).
    600 x 450 - 94K
    600 x 450 - 91K
    600 x 450 - 90K
    539 x 832 - 198K
    295 x 64 - 8K
    305 x 55 - 7K
    Post edited by cgidesign on
    edited January 2022
    By diffuse I mean the base color in the diffuse section. By volume I mean the volume section with thin walled off. Below an example of skin driven only by the translucency color. As for Marty I can't help because I don't have that figure, but it's weird that the maps are different usually it isn't.
    The diffuse roughness activates the oren-nayar shading that's more realistic than lambertian. But it's not a big difference with most materials so it's not usually used.
    433 x 581 - 80K
    Post edited by Padone on
    Thank you for the clarification everyone.
    I'll play a little bit with base color in conjonction with the translucency color to smooth the transition between skin color body parts.
    I'll just go with the flow between the two (translucency and base color) until I'm satisified by the results ^^
    Cheers
    yes
    edited January 2022
    Sue in some circumstances that is the better choice.
