Hair/Fur with Angles and Not Smooth
mwokee
I have renders where hair and fur has hard angles which does not look natural. I read that you change the SubD to fix this. Where do I find the SubD to change it? Are there other settings I should use to smooth out hair/fur? Thanks
Actually, if tghis is strand based hair, you want to increase the segments per strand. I can't recall the exact setting but it is in the Parameters pane.
