Need help with layout
Hello,
So the other day I deleted some tabs on my workspace thinking I'd just add them back later. But as it turned out, way too much time had passed and I forgot how to put the time line and animate tabs back on the bottom. Anyhow, I reset my workspace and style and figured I'd just customize my layout again. I use City Limits and darkside. So I just customized it to what I had before....... only it's a bit backwards. I need "A" to be where "B" and "C" is, and "B" and "C" to go where "A" is. But not just the tabs. Each letter is actually a window and that's what I need moved. My left side had the 2 windows and the right side just the 1. But I can't seem to figure out how I did that all those years ago. And my mind just can't get use to the backwardness and I would like to get back to what i am use to. Can anyone help? Sorry if I didn't describe this too well.
Redacted
Thanks Cgidesign. That is what i was looking for. I knew it was easy, which is why i think i never took the time to save the layout. Not sure why I was overlooking the undock pane group. Thanks for your help.
Cridgit...... thanks for trying to help. it wasn't the tabs i needed to move, it was the whole window of tabs (pane group). Cgidesign had the answer, so now we know how to move groups.
If you open the option for a pane group - the line/hamburger button in the top corner nearest the Viewport, or right-click the tab - there is a command to Undock Pane Group. You can then drag it by its top bar to the desired position, and release it whjen you see a line of the hoghlight colour.
