"Student" type lamp with glass shade and chimney.
I cannot find a model for a vintage lamp with a 'student'-type glass shade and chimney. Something like the lamp in the first attached image, but a single table lamp of the size and shape in the second image (but with a nicer shade).
Note that the second image is from a juvenile prep-school novel of 1908, and the lamp is referred to in the text as a 'drop-light'. This was before electrical outlets were standardized: if a building was wired for electricity, it was wired 'for lighting', since there were no general receptacles. So a table lamp (styled with a chimney like an oil lamp) would have a cord that would be screwed into a bulb socket from the wired in electrolier (chandelier). Re-creating this lamp with cord will require creative use of a rope-type prop.
Edit: actually, looking closer, it appears that what was directly attached to the light fixture was some kind of rigid u-shaped extension attachment, into which the flexible lamp cord is inserted (so only the extension thing itself would need to have a screw base). Maybe.
This set has a similar lamp: https://www.daz3d.com/treasury-of-books, it is Pre-Iray so the shaders would need adjusting. And these: https://www.daz3d.com/vintage-lamps-iray are the only other vintage style lamps I've seen. None exactly like your first image though.
Just to double-check - you're looking for somethig like this?
(No, I don't know of one in the 3D world - I just happen to live in an Amish area).
Looks like the new https://www.daz3d.com/betty-stained-glass-lamps product may serve.
