V4 & M4 Poses (Genesis)
deleted userdeleted user Posts: 1,204
My V4 and M4 poses have stopped working on genesis. Help please? I have no idea what's going on here.
These are the same poses I was using a month ago, "Before I updated" So I know it had worked in the past. Now all the sudden, notta.
    I updated to DS4.7 as well, and I can see no difference in posing Genesis using V4 or M4 or H4 or even Freak 4 poses.
    What poses exactly are you trying to use? Are there any errors, and have you looked at the log file?
  • deleted userdeleted user Posts: 1,204
    edited December 2014
    Log files fine. No errors, and its all of my V4/M4 poses... not just 1 or 2. Every one of them stopped working.
    Post edited by deleted user on
    I must say that I am baffled, perhaps you could try reinstalling Genesis Starter Essentials though DIM and see if that helps?
    I even tried this on a Genesis loaded from a DUF Scene file, and the poses still worked. Maybe someone else can offer more hlp, just hang on for a little while.
  • fixmypcmikefixmypcmike Posts: 19,701
    Do you have Genesis as a whole selected, or a specific body part?
    Does it work with a default gray Genesis with no skin or clothing added?
    Do Genesis poses work normally?
    Reinstalled GSE
    Genesis is selected as a whole,
    No mats
    Genesis poses work fine
    V4/M4 poses do not work still.
    Need a clarification of "poses". Do you mean the Poser format files (.pz2) that change the material setting or do you mean pose presets that change the position of the figure. It would make sense that the material presets wouldn't work on the base G2F and G2M as: (1) they don't have the respective V4 and M4 UV sets unless you bought them (2) If you did have the V4 and M4 UV set you would still need to convert the presets file format to DS's new .duf format.
    Post edited by jestmart on
