Render problem with Mech 4D's hoplite fibermesh
Helvetica 2013Helvetica 2013 Posts: 15
Hello,
I'm having a problem with Mech 4D's Hoplite figure. The figure loads fine and renders really nicely, but the fibermesh crest renders white. Is this happening for anyone else?
  • Cris PalominoCris Palomino Posts: 12,554
    Try saving your scene, restarting DAZ Studio and reloading your scene and render again.
  • MattymanxMattymanx Posts: 6,997
    what are the surface settings
  • Richard HaseltineRichard Haseltine Posts: 108,459
    That does look like a failed shader compilation. Go to Edit, or Apple menu>Preferences and note the location of the temp folder. Then go to that folder, then into the Shaders folder, then the brickyard folder, and delete the contents. Try rendering again, if that fails try reapplying the materials to force DS to recompile any Shader Mixer shaders.
  • linvanchenelinvanchene Posts: 1,386
    edited February 2015
    edited and removed by user
    Post edited by linvanchene on
  • Helvetica 2013Helvetica 2013 Posts: 15
    Yes, it's very strange. Thank you all for commenting, I deleted my temp files and reapplied the mat. Even went into a modeler and created a new texture. But I'm still rendering all white on just the fibermesh. I've attached the surface settings as I see them. Thank you all again.
    492 x 367 - 88K
    Weird. I only did a quick test in 3Delight and it seemed to work with DS4.7.0.12.
    Even in the OctaneRender plugin with autoconversion the Fiber Hair Crescent loaded in the proper color.
    I love seeing Octane renders. I'm stuck with an AMD card for a while, but as soon as I can I'll get an GeForce and get it. Awesome stuff!
