Change bit depth?
I need to export a png sequence into Davinci Resolve, however I can only import a bit depth of 24 and naturally DS exports at 32.
Is there anyway of changing this without editing 300+ frames in photoshop?
Thanks!
    Irfanview
  • phazdvideophazdvideo Posts: 21
    edited January 2022
    PerttiA said:
    Irfanview
    Thanks but I'm asking if there's a way of changing the settings in DS?
    Post edited by phazdvideo on
  • AscaniaAscania Posts: 1,856
    No.
  • Richard HaseltineRichard Haseltine Posts: 111,382
    edited January 2022
    Render a Beauty Pass canvas (Advanced tab of Render Settings) and when you save the render a folder with the same name and Cancvasses appended will be created holding .exr files with plenty of bits.
    Had to wait until I got home... How do you get 32bit PNG's out of DS? Mine are 24bit.
    I suggested Irfanview as a tool for batch conversions. I have converted 1000+ texture files with it in one go and it didn't take but a couple of minutes.
  • prixatprixat Posts: 1,627
    Any 24 bit PNG that has transparency is called 32 bit.
    I tried rendering a png without transparency but it still came out 32 bit.
    Premiere never had this problem, this seems to be a Divinci issue with 32 bit.
    Updated my Irfanview to the latest version and I must appologize, although Irfanview still shows the image as 24BPP at the bottom, and reserves memory as 24bit image, the Image Information states "Original colors: 16.7 Million (32 BitsPerPixel)"
    If you save the file with Save As, the PNG save options has check box for "Save Transparent Color", with it unselected the resulting file says "Original colors: 16.7 Million (24 BitsPerPixel)" -> With Batch processing it would not take but a "second" to save the images as 24bit images.
  • Make sure you are comparing the matching numbers - I was thinking you wanted 24 bits per channel, rather than a total of 24 bits, for compositing while Daz Studio rnders are only 8 bits per channel.
  • marblemarble Posts: 7,500
    edited January 2022
    Thanks!
    I'm confused. I save to .png image sequence every time I make an animation and I create the video file in DaVinci Resolve. However, if I look at the image information those .png files are only 8 bit.
    501 x 352 - 30K
    Post edited by marble on
  • cgidesigncgidesign Posts: 442
    edited January 2022
    @marble
    that is 8 bit per channel.
    8 bit red
    8 bit green
    8 bit yellow
    8 bit alpha
    32 bit altogether
    @phazdvideo
    Resolve officially supports 32 bit png - is there a reason you want png without alpha channel?
    https://beginnersapproach.com/davinci-resolve-stills-images/
    Post edited by cgidesign on
    cgidesign said:
    @marble
    8 bit red
    8 bit green
    8 bit yellow
    8 bit alpha
    32 bit alltogether
    @phazdvideo
    Ah I see. However, I have no problem using my .png image sequences with DaVinci Resolve. I use the free version and have since version 15 (it is now 17).
    edited January 2022
    XNConvert - https://www.xnview.com/en/xnconvert/ - is designed as a batch processor and will do many things inlcuding reducing color depth.  free for personal use.
    Same company makes XNView MP, also free for personal use.
    Licences are perpetual if you need to buy one.
    Post edited by Mattymanx on
