Setting X Y Z angles for objects manually?
How can I set the X Y Z rotation angle of an object manually?
Say I want to rotate an object negetive 90 degrees from a starting position? When I try to do it in the window, I never get it to a precise 90. Is there a manual setting?
The normal way, in the Parameters tab.
Thanks! I'm still learning my way through all the stuff.
