problem need help thankyou
hello my problem is that I can no longer load genesis or open a project, this morning I tried to render but the rendering was not done, since it no longer responds and no longer opens projects 4 d attempt own installations do not work either
my workstation bi xeon 2.60, 64 GB ram, rtx 3090 my collection is on 2 hdd ....... thank you for helping
Might need some more info here. When exactly does Daz become unresponsive for you? During the render, or when attempting to load Genesis or a project? How many morphs do you have installed? If your Genesis character has a ton of morphs, it may take awhile to load into the scene, giving the appearance of unresponsiveness, but after enough time it will come up. If you want to significantly cut down on these load times, you have to go into your Daz content library and manually remove morphs. Or if you've installed content via Daz Central, simply uninstall unused morphs through there.
What happens when you try to load content? Are there files showing in any of the content panes?
