Advanced Ambient Light not rendering
sinfanysinfany Posts: 190
Hi, as you can see, something's wrong with this picture... the light is not showing up in the render and the only options I'm getting are Light Color and Light Intensity.
What did I do wrong and how can I fix it?
Much appreciated
  • SnowSultanSnowSultan Posts: 3,774
    Try reinstalling the light and see if that helps.
  • FistyFisty Posts: 3,416
    The means that some of the files didn't get put in the right place, AoA's lights have additional parts installed to different areas than normal lights. If possible let DIM install it, it should know where everything goes.
  • SpitSpit Posts: 2,342
    I see you're using the new Studio 4.7. If reinstalling the lights doesn't help, submit a support ticket. Others have had problems with these lights and flagging in the new Studio but nobody has mentioned this specifically so reinstalling may fix it.
  • sinfanysinfany Posts: 190
    Thanks everyone for your suggestions. I reinstalled the lights and it worked!
  • eiliestleiliestl Posts: 100
    edited May 2015
    Reinstalled them . And they still aren't working...
    Post edited by eiliestl on
