Strand based hair: unwanted strands
Hey,
maybe someone of you have an idea.
With strand based hair, I get some unwanted strands, which differs in color from the rest of the hair.
See screenshot.
Is there a way to get the hair color more consistency? I played around with the shaders, with no success.
But the shader is anyways the same.
  • Cant really tell from the small example image if its the same problem seen frequently but if it is try reducing the opacity of the selected hair to 0.99 in the sufaces tab.
  • SolitarySandpiperSolitarySandpiper Posts: 566
    edited January 2022
    This is a common occurance with an easy fix...
    1000 x 1000 - 1M
    1000 x 1000 - 1M
    Post edited by SolitarySandpiper on
  • Hurdy3DHurdy3D Posts: 1,076
    Strange, somehow my example image is gone.
    I  have an other issue. I see the same strains also an your example, but it's obvious with blond hair.
    I just did an other example, you see a lot highlights and I think the hair shouldn't have these shiney strains. This happens with most Strained based hair, but not with the "traditional" hair.
    711 x 790 - 508K
  • chevybabe25chevybabe25 Posts: 1,321
    You can try changing the tiling on all the surfaces to something like 50x horizontal or more.
    You can try removing the texture maps from the surfaces and just use the standard colors.
