Adding to Cart…
Took my new UFOs for a testride...
Experiments
51 new posts, and I don't get a single notification... sigh.
Well, sorry to pic-drop and dash, but I promise I will come back and look at everything tomorrow! Merry-but-slightly-chaotic Christmas / Holiday Season to all :-)
In the morning Harry is still feling weak and Snape is still unconsious. So Harry tries to summon something to eat.
... Through the glass of the kitchen door.
He decides that isn't a good idea.
...and to you! Nice one!
Error 504 - the making of..
thank you Sven :)
added a couple of sets, need to learn more about camera in d/s and procedural shader in 3de; anyway carrara and d/s work effectively together.
50 seconds per frame for this low resolution
I think that looks quite good and renders reasonably fast. All diffuse txtures in direct light look slightly overblown, not necessarily a bad thing, it adds something to the general look. However you loose a lot of detail if that's what you are after.
What GI are you using here?
that's correct, I added glare in post to enhance overall radiosity but some shaders need to be adjusted and low resolution does the rest. Attached a shot with and without post correction at a good resolution for animations, I would decrease the sky light a little bit but the outcome is pretty realistic to me
about GI, actually I've been using AO with soft shadows in 2 flavours slightly different: one for overall ambience and the second to "fake" bounce lighting and radiosity; this allows to get realism in less render time than IL
Tks for sharing! Yeah the post- processed one looks more like Aces or Unreal tonemapping, I like it, well done:)
Most of my work until this year has been done in 3delight. Then I made switch to Iray and have not returned to it, until recently. Did a couple of render's in 3delight and attached the lastest one done because, while amazing I have done a bit too much of renders in Iray. Guess you could say a return to the roots of sorts.
Looks good:)
Meanwhile, Petunia is determined to esape. And deal with these *freaks* in her house.
Merry Christmas, 3Dl'ers! This is my Missiletoad (a Mistletoe pun floating around the internet this season). May your day be merry and bright (but not explosive.)
Nice!
...king of the hill...
...Xchanging Xformation...
A message was sent to Hogwarts about the situation, and Minerva turned up to investigate. She tells Harry that Snape will probably be asleep for some time. She sendst Dobby to help out.
Dudley wakes to find a breakfast which is absolutely *not* on his diet. He doesn't dare trust it.
You can almost feel the cold with this one. Excellent image.
Thank You! I wish you a Happy and Creative 2022!
"On duty"
Looks good! What env is that?
