MRL dForce Long Morphing Hair Problems
After loading the product only the scalp can be seen in iray preview. Oddly the hair can be seen in texture shaded but its just a big blob. Can only see the actual hair if you render it. I have no clue.
That is normal for dForce hair.
It is ressource intensive.
You can make it visible in preview by setting preview to On and tesselation to 2 or 3, in the parameters.
Thank you very much! Your fix, was the solution. Is it possible to message the product makers directly? Or is the forum the only way to get help?
DAZ handles customer service for the PAs, so it's best to put in a support ticket when there is a problem.
