Render to New Window: Is the render window (bckgrnd color) customizable?
When rendering to a new window, I would like to change the default grey background (the border area around the image when the window is larger than the rendered image) to black. Is it possible to apply customizations to the Render Window without changing the rest of Studio's user interface? If so, where are those settings? I want to preview my renders against a black background before saving them.
Thank you, for your time.
Window>Style>Customise Style, the Viewport background colour is the last group on the left of the dialogue.
Thank you. Thank you so much.. I'd given up.
Nope.. that wasn't it.. I'm wanting to change the render window that pops up when I start a render. See attached
Ah, I misunderstood. That is the Background Colour defined in the first group of the same dialogue, but it is sued in several places so you will need to be careful not to make text invisible as you edit it - there is a Preview button in the Customise Style dialogue which will let you try things out, and you can then cancel to revert for a fresh go.
