Default render settings cause intense light (Dome and Scene)
There appears to be some issue with the Dome and Scene render which causes it to render is extreme brightness (all settings are default, I haven't touched anything). Sometimes this doesn't appear to happen until the camera is moved around a bit, and then it will suddenly turn bright light and stay that way from then on. Dome Only and Sun/Sky rendering never have any issues whatsoever.
This is extremely easy to replicate locally so I can only suppose it's something no one else is encountering?
I have a GeForce GTX 1650 card, which I have tried to disable (CPU only) but the problem persists.
Screenshot of intense light issue attached:
Post edited by jamesramirez6734 on
Turn off the camera light.
Ah thank you! That thing really is blindingly inconsistent.
