Why I can't c anything [solved]
FuncubeFuncube Posts: 0
edited December 2014 in Daz Studio Discussion
Post edited by Cris Palomino on
    Insufficient data to process your query at this time. Some system specs would help along with details on how and where you installed.
  • Richard HaseltineRichard Haseltine Posts: 109,002
    Was this a new install of DAZ Studio or an update? if it was an update, wa DAZ Studio closed when you installed? If not, make sure DAZ Studio is closed, uninstall and reinstall. Failing that, go to Window>Workspace>Select layout and reload your layout. If that fails you might also try Window>Style>Select Style and pick any style from the list. If none of those help, what are your system specifications?
  • FuncubeFuncube Posts: 0
    Problem Solved, Thank u very much :)
