Adding to Cart…
thanks HeraldOfFire, I look forward to clarification as well. I figure that was simpler then that staff. Reflectivity location map (similar to the skirt), with a 2-tone ambient and diffuse spiral band. it changes color from light aria to being in shadow. Hence the name "Staff Of Render Hell". lol
Lets stick with cloth and mirrors, that is exactly what I want for a few outfits. Just for the coolness of it. :cheese:
Thank you for pointing that out.
Yes, that is a specular map and it works the same in Reality. The brightness values indicate how much light is reflected at that point in the surface. For example, a brightness of 50% ( rgb 127,127,127) will reflect 50% of the light that falls on that point.
Cheers.
maybe i missed it, but so you have to have Reality installed for the update to work? I recently had to do a factory reset to my laptop, and i have not installed Reality 2.5 again, but i was wondering if i could just wait for 4 to come out and install the update only. Or do i have to install 2.5 first and then the update to 4?
Hi decoboy.
No, you don't have to have Reality 2 installed. Reality 4 is a brand new program that has no shared file with the previous version.
Cheers.
Thank you for your quick response. I will hold off on installing then and wait 4 hours for Reality 4 to come out. Thank you again for the help and the great program!
Absolutely. My pleasure.
Product is now live in the store. Upgrade pricing is correct. Got it! :-)
I've only had the new Reality 4 for less than an hour, but I'm already loving it. The material conversions are amazing, even improving greatly upon the already good Reality 2 conversions. It's backwards compatible with the R2 lighting presets as well, which is handy because for some reason I can't seem to locate the new presets yet (anyone want to lend a hand in that area?)
It handles volumes brilliantly too. Easily the most complex of substances, Reality 4 gives me a solid base to work with for future volume editing. So, hats off to Pret-a-3D for this latest plugin. It's worth every last penny and more, and was well worth the long wait. It's clear a lot of hard work went into this, and it's answered practically all my Luxrender prayers in one neat little package.
Bought Reality 4 DS from DAZ couple hours ago... Basically just an exe file... NO installation instructions.. NO Reality manual..
Currently useless... what is going on..?
I have the manual. I ran the installer exe file, and it's in the Reality folder in my Program Files.
@ziggie
When you run the exe there are 3 install paths. The first one is the most important. You have to install Reality where your Studio exe is (Program files/Daz3D/DazStudio4). The other two (for props/lights etc) can be installed wherever you want them.
Run Reality from Studio and you can find the manual in Reality/Help. Its in PDF.
I click the exe file all I get is.. error 0xc000007b.. and would have expected at least some basic installation instructions in the Reality 4 DS zip file..
Update: Redownloaded from DAZ... exe file is running now.. sighs... now have the options and paths to install to etc.
Well then. Seeing as you need to install Reality, to get to the help file that explains the process of installing reality. :ohh:
What should be installed first, LuxRender, or Reality?
I can only assume that the unlimited-time upgrade is from your website and not at DAZ 3D's store?
I decided to purchase it now and get it over with. I want to purchase it from the DAZ 3D store because of the DIM installation possibility. I have no idea if it is available in DIM format, but just in case it is or will in the future.
I woke, I bought! :)
Looking forward to getting to grips with it when I get some free time!
Currently, it is not installable via DIM. It had to be installed manually.
I'm on Windows 8 64-bit, but the download options are a little confusing beyond that...
What's the difference between an 'archive' and 'installer'? Should I download the 'OpenCL' version by default?
Also, is there a new guide or is the Reality 2 user guide sufficient?
And, having taken a look at the new videos, I understand how to change an object's material value within Reality, but while glass, skin, metal are all self-explanatory, what would 'null' be for?
The Reality 4 user manual builds upon the R2 manual nicely, giving you a decent overview of the new functions. That being said, if you're familiar with Reality 2, there shouldn't be too many surprises here.
Null materials are used when you don't want a surface to render. This can be a variety of reasons, but the most common uses are opacity maps which work by mixing a null material with the base material (usually glossy), so that the 'null' handles the invisible parts of the surface, while the glossy handles the visible parts.
So, in effect Null means 'invisible'.
I can see some search references to my GTX 770 having CUDA and OpenCL. I'll try that version, thanks.
Interesting to learn about null... Thank you. Opens up possibilities.
Just need to know whether to download the 'archive' or 'installer' version of Lux (or both, but that would make me wonder why it isn't just a single file). Then I'll hopefully be on the road to becoming a fully-fledged Reality user. :)
Buying this was the first thing I did this morning. Been waiting for it for what seems like 2 years.
For me it is the salve to an ill-fated sojourn into the Octane renderer. That was a nightmare.
I've installed Reality 4, and the stand-alone has run ok and it's registered. But Studio keeps opening Reality 2.5. Doesn't seem to recognize 4 at all?
(Mac & Yosemite, version purchased from preta3d.com)
Edit - seems the plug-in isn't getting copied to the Daz Studio folder.
- And the item "Top Mesh Light" produces an error
"Could not open file :
File does not exist."
I installed the windows 64bit with no probs this end it opens the new version 4 ect, though in the render dropdown in Daz Studio I do have the old "Reality Render" still there but at the bottom is the new version thats called "Reality Render Editor"
I did install to the defaults that the installer provided.
Steve.
The archive is a ZIP file, and the installer is an .EXE, take your pick, they both do the same thing. The installer is easier to use if you are not familiar with installing your own software.
Got my zip....
2 questions
Do I uninstall the version 2 I have?
Where do I install all this... see the screen grab below
Thanks!
Richard
Go to Help -> About Installed Plugins and find 'Reality DS' in the plugins box. Check that the status icon is green. The 'Reality Engine' plugin is for 2.0 so don't confuse the two :)
I've manually copied the .dylib into the plugin folder to get it working.
Cheers for the replies though!
Grabbed it as soon as I saw it in the store. The introductory price is a great deal, didn't bother trying to go the upgrade route.
So far loving everything i am seeing. I have had a little trouble using the "water" material. Lux complaining about a missing disp map I think, but too much other new features to worry about it right now. LOVING the simple GPU render options, although again I got hung up on a odd Lux error. I had used the checkboxes to enable two GPUs after setting the "Num GPUs" to two and it throws an OpenCL error about something must be "2 not 3". Figured out if I set the "Num GPUs" back to 1 but leave the enabled GPUs at two it will do Pure GPU rendering. And what a difference in speed! Only the "Sun" light seems to work, will need to read up on Pure GPU rendering, but that will just make the work more fun trying to figure out bounce lighting .. :D
Thanks Paolo for delivering this new version! I have been waiting on pins and needles, mostly for new the material conversion of newer figures and such.
Homerun in my book!
Bravo!
The file selection window (for loading new maps and whatever) looks very blurred on a Macbook retina display.
