Why would I want Daz to make _icon's for every render?
its unnecessary clutter in my render folder but I would like to know where they come in to play?
I have yet to come across a situation where I saw them.
If they are not all that useful is there an option to never get them with my renders?
Thanks!
    edited December 2021
    Thanks!
    They are used in the program if/when one is using the Render Pane in D/S.
    Yes, you can avoid getting those by selecting another folder to put your renders into.
    Post edited by Catherine3678ab on
    1. Window>panes(Tabs)>Render Library
    2. Open the option menu (the lined button in the top corner, or right-click the tab)>Render Directory manager...
    3. Select the current path, click the Edit... button, and select a folder that isn't used for images.
    To stop DS from using the new location for renders,
    1. Do a render
    2. Click the picture icon next to the name of the Render Library at the bottom of the render window
    3. Select the folder icon.
    you can now specify a folder to save to, rather than a render library, and as long as it isn't in an active render library you won't get thumbnails.
