Bryce 7 Pro
I can not seem to get this to work. It appears to have been down loaded but I can't access it. Is there another program I need, other than DAZ, to operate or access it.
Thanks,
Neal
Thanks,
Neal
Bryce 7 Pro doesn't need any other program to work. It is a complete software on it's own.
Make sure that you have downloaded the complete set of files, There are 4 files The Bryce_7.1.0.109.Win32.exe or Bryce_7.1.0.109.Mac32.exe is the main program file.
BTW please note that Bryce 7 pro does not work on Mac with OS X 10.7 or greater. This is shown on the product page.
You won't need to install the bryce lightning file unless you want to set up a render farm.
When you say you can't access it, what exactly do you mean? (Can't find it, nothing happens when you double-click on the installed Bryce 7.1 thumbnail or select it from the Windows Start menu, an error message is displayed when you run it, it won't accept your serial number, you downloaded it but get an error message when you try to run the installer, or something else?)
Also, I can't remember the details but there was something about DIM and installing Bryce, like you had to have the order right between content and the application or something, I forget what. Are you using DIM to install? If so, do any Brycer's with DIM recall what that issue was? (I just install it manually myself, so I don't remember the details.)
Thanks alot folks. I got it. A bit of operator ignorance was my problem. Well a lot of operator ignorance.
Thanks again
Glad you got it working. Now we look forward to seeing what you can do with it.
We are very helpful here, so don't be shy about asking questions.
