Daz install manager with Windows 11
alardron
To keep it short, new PC with Windows 11 Pro. Daz Install Manager crashes every time I attempt to open it Windows Event view is pointing at LIBEAY32.DLL library as the suspected file. I would not worry about it except Daz Central does not give enough options for directory control. Every time I attempt to change my default Base Path, the CMS stops working correctly, i.e. it cannot find the Prostgre DB. Secondly Daz Central is the pits to begin with, as it is too basic in design and gives very limited in scope.
Below is the error log. and since we can no longer download DIM, we have a problem especially when Daz Central states that the base location is manager by DIM.
Faulting application name: DAZ3DIM.exe, version: 1.4.0.67, time stamp: 0x5f2a38e1
Faulting module name: LIBEAY32.dll, version: 1.0.2.8, time stamp: 0x573e3641
Exception code: 0xc0000005
Fault offset: 0x00000000000e6643
Faulting process id: 0x6eec
Faulting application start time: 0x01d7f8dfceaba0b6
Faulting application path: C:\Program Files\DAZ 3D\DAZ3DIM1\DAZ3DIM.exe
Faulting module path: C:\Program Files\DAZ 3D\DAZ3DIM1\LIBEAY32.dll
Report Id: 6eb12351-e389-4fa6-b275-dfc50532c507
Faulting package full name:
Faulting package-relative application ID:
You should file a ticket with Daz3D so that they can look into it
https://helpdaz.zendesk.com/hc/en-us/requests/new
Been informed that you need to install the newest verrsion of DIM which is 1.4.0.80. It replaces the version of OpenSSL that's used
http://docs.daz3d.com/doku.php/public/software/install_manager/change_log_1_4_0_80
