Odd Categories problem.
Couldn't find anything in forums. I updated from 4.6 to 4.7, and it loads but all my categories files show that directory is C drive and unable to load.
Trying to reinstall to see if screwup on loading. Any ideas?
Thanks
Thanks
DO you mean items in Categories have the wrong path? Where is your content located?
Its located under default directory of my library. But when it pulls up categories file, everything has exclamation point and if you do properties it says directory c:\.
It looks like there are multiple references. Select the icons, right-click and choose "Remove orphaned references".
I told database to rebuild then reimport categories. everything is there. But any new content it refuses to see.
i.e. I got Dh kitchen when it was on sale, installed through content manager, and when I searched it is no where to be found yet search of database shows it is there.
I.e. 4.6 would put it in unassigned, but 4.7 puts it thin air
No idea how different 4.7 database is, thought it would be a straight look at 4.6 and go on its way. Trying to maybe do another rebuild. No idea what is going on with 4.7. Didn't have problems with 4.6 except for slow sometimes. 4.7, its fast but categories took a back seat..
What options are you using in the "Scan Known Directories for Files" dialog? Were the new items installed manually or using DAZ Install Manager?
