Genesis 8 Female XprssnMagic
cant find this good looking set , this says its a free standing application, does anyone know where its at?
  • ProPoseProPose Posts: 547
    Look for Vendor gryffnn/Elisa Griffin
  • VicSVicS Posts: 1,273
    search within daz software, i didnt see where to that, can you tell me or do you mean search the website for Elisa? thanks
  • How did you install? If through DIM there should be an entry in the Installed tab - right-click on that>Show Installed Files will show you where everything went.
  • For the previous (G2&G3) the app loaded a desktop icon (Windows). You set up your expression there, then it has a copy/paste type function to ge tthe expression on to your scene.
    So outside Daz you run the script. Copy it to clipboard. Then paaste it using the script inside Daz studio.
    I think you can access it through /Scripts/utilities
    i had install through DIM since it was not even in daaz central - ill check ok thanks for everyones help!
