the 8/16/32/64 GB RAM argument
StratDragonStratDragon Posts: 3,277
edited December 2021 in The Commons
argument settled.
Post edited by StratDragon on
«1
  • frank0314frank0314 Posts: 14,734
    Unless I zoom in in my browser I can't see what it says. The image doesn't open.
  • StratDragonStratDragon Posts: 3,277
    my bad!
    234 x 212 - 7K
    What was the argument and how does the image settle it?
  • I got 128Gbs is there some wrong with this?
    the argument for 32 or 64 gb RAM. my render hit 32.5 and I tend to optimize and add in post work.
  • HylasHylas Posts: 5,239
    So are you saying that better stats are... better?
  • nicsttnicstt Posts: 11,715
    My current rig is 5 years old (ish); it has 64GB and I've have never ran out of RAM; I have had renders use as high as 58GB.
    My next rig - likely next year will certainly have 64GB and likely 128GB.
    I certainly wouldn't reccommend less than 32, but: balance your system and get what you can afford.
  • DandeneDandene Posts: 162
    I've been running on 16gb since I began rendering and. . .desperately need to upgrade.   A lot of my system needs an upgrade.  My ideal was 32gb but I might bump that up to 64gb.
  • If you have a 3090 or a Titan RTX, then you're gonna want 128gb of system.
  • AgitatedRiotAgitatedRiot Posts: 4,602
    8 Gen 8s, outfits, environment, props, and lights.
    Memory on GPU all used 12Gb
    GPU load 100%
    CPU used 100%
    Memory on System 65 Gb all Used.
    Why I went to 128 Gb of memory.
    Post edited by AgitatedRiot on
  • UHFUHF Posts: 518
    The real question is how much time does youre render's optimization consume.
    My PC has 64GB of RAM which felt very over kill with Octane. Octane isn't a glutonous memory pig from the land of insufficient light.  You have unlimited RAM for textures with Octane.
    I've used Octane and Reality more than Iray\3Delight. IMO Iray isn't very good and products often have preset textures for some other flavor of Iray and you're often left guessing what shader set up the vendor used/tweaked.  Using stock Iray has the advantage of mostly kinda generally doing what you want without too much texture/shader work on the render.  This is good.  The down side is playing guessing games with shader adjustments which makes render tweaks time consuming and incredibly slow.
    Octane was a butt load of work for shaders up front, but they worked, and did what you wanted.  Tweaks and test renders were super fast and easy.  (IMO this makes up for Iray's inability to tweak renders quickly.) Revamping an Iray render to Octane was generally time consuming. (I put in a good 6 hours on one render so I know of what I speak.)
    This render was done with 2 GTX 1660s that only had 8GB of RAM.  The scene pushed 11.5GB of RAM, and I'm certain that my current setup with 1X RTX 3080TI with 12 GB of RAM, with 64GB of system RAM would simply choke and die on this in Iray.
    https://www.daz3d.com/gallery/#image=988816
  • nonesuch00nonesuch00 Posts: 18,765
    I have 32GB RAM and have had scenes that got close when CPU rendering but nothing has ever exceeded that yet so I think 64GB is good but 128GB is probably excessive.
    Post edited by nonesuch00 on
    saying IMHO that 32GB my not cut it as a viable baseline when building or buying a rig especially as newer assets need more and more overhead.
    oppoppo
    Render test that I made some time ago;
    Case a) One lightweight G8 character with lightweight clothing and hair
    Case b) Four similar G8 characters plus an environment
    Case c and d) started increasing the SubD on the four characters to see at which point the rendering would drop to CPU
    Using W7 Ultimate with i7-5820k, 2070 Super (8GB) and 64GB RAM
    Case c) The last one that fit the 8GB VRAM, needed 38GB's of RAM to render.
    615 x 574 - 40K
    Post edited by PerttiA on
    I'm currently getting by fine with 32.
    Yeah, it isn't that bad, but when I updated from 32GB to 64GB, the responsiveness of the system while rendering did improve noticeably
    I have 256 gigs and I still notice slowdowns now and then :)
  • hjakehjake Posts: 1,290
    In my experience a rule of thumb for DAZ Iray is 3 to 1. Therefore a 12GB VRAM graphics adapter is best paired with atleast 36GB (64GB) of CPU RAM and 72GB (128GB) of CPU RAM would be best for a 24GB VRAM graphics adapter. By this measure an 8GB VRAM graphics adapter can get by on 24GB (32GB) of CPU RAM.
    However if you are building a new PC and can manage the budget starting at 64GB RAM is probably a reasonable investment if you think you will keep the computer long enough to upgrade the graphics adapter within 12 to 36 months.
    I don't think the "who has the most VRAM" marketing battle will really take off for atleast another couple of years. Real-time ray-trace rendering is still in its early days for Game developers and blockchain computing/mining is not as worried about size of VRAM as they are about parallel processing and GPU speed.
    So Nvidia is not in a hurry to make their graphics adapters with 48GB VRAM. The 3D artist rendering market is a VERY VERY tiny portion of their card sales.
    Post edited by hjake on
    hjake said:
    In my experience a rule of thumb for DAZ Iray is 3 to 1. Therefore a 12GB VRAM graphics adapter is best paired with atleast 45GB (64GB) of CPU RAM and 72GB (128GB) of CPU RAM would be best for a 24GB VRAM graphics adapter. By this measure an 8GB VRAM graphics adapter can get by on 32GB of CPU RAM.
    Not bad advice smiley
  • kyoto kidkyoto kid Posts: 41,966
    ...one advantage Octane has over Iray is out fo core rendering. which is really helpful if you don't have a card with a whopping amount of VRAM. Blender's Cycles has it as well.
    That said I'm still somewhat behind the curve as finance are tight that I have to make the best out of what I have for now: 24 GB system memory and a 12 GB Titan-X.(also have a 12 GB 3060SC but couldn't get my MB (X58) to support it even given adjustments I made.
    I have an update specced out (which will be W11 compatible), however it means getting the funds up for it:
    Intel i9 10900KF CPU 10c/20t
    ASUS Prime H570+ MB
    64 GB DDR4 2666 memory (2 x 32 GB leavng tow slots open for later memory upgrade)
    Noctua NH-D15S CPU Cooler
    Samsung 980 500 GB M.2-2280 NVME Boot drive.
  • SephirothSephiroth Posts: 12
    I have:
    3070 Threadripper
    256GB DDR4 RAM
    RTX3090
    ROG Zenith Alpha II motherboard
    My renders barely pull 20GB of RAM, and bluje screen my PC if I run the CPU as a fall back option. The RTX 3090 runs as hot as if it were crypto mining but at only 8% utility using 9.7GB of GPU memory. What am I doing wrong because by rights this PC should be annihlating anything I throw at it and Daz is instead demolishing my PC...
    3846 x 2150 - 4M
  • Richard HaseltineRichard Haseltine Posts: 108,561
    Change one of those graphs to CUDA to see the work that is being done by the GPU - th defaults do not cover Iray activity
  • TaozTaoz Posts: 10,272
    Sephiroth said:
    I have:
    3070 Threadripper
    256GB DDR4 RAM
    RTX3090
    Presuming you aren't using watercooling, is the case well cooled, with good airflow?  That's the most important thing when it comes to air cooling.  If the air inside the box is too hot, even the best CPU/GPU coolers won't help much.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,259
    so basically, what ever you have, you will always need moresurprise
  • LeatherGryphonLeatherGryphon Posts: 12,143
    There must be a "Murphy's Law" that covers that situation.enlightened
  • IvyIvy Posts: 7,165
    Isn't that the truth laugh
  • Faeryl WomynFaeryl Womyn Posts: 3,741
    You're all quoting how much ram and vram you have, but I don't hear anyone saying what's in the renders and how long it's taking. It seems to be the one thing no one is mentioning and that would be good information to know. Quotes don't mean squat without all the information.
    Ive had Studio using around 56GB.
    My next build, which is soonish, as this is now 5 years old or more will be 128
    Too many variables really.
    I've had single character scenes with a few props use 18+ GB of my 3090.
    I hate optimising - takes too much time very often. I have been known to do it tho, although if I have an issue in Studio, I take it to Blender.
