Subfolders possible for "My Library" presets?
Over the years, I've made 100s of scene subsets of props, tweaked sets, etc. Can you make subfolders? Example: My Library > Scene Subsets > Actors or... My Library > Scene Subsets > Props
Just a thought. Searched but results were how to make a ss -- nothing about organizing them. ;)
You can make as many, and as deep, as you like, but you will lose metadata (content type, like Scene, or Materials; compatibility, and any that you defined yourself, etc.) if and when you move the files. You could re-save them in the right place, or edit the metadata after, if you want it back.
If you use the right-click options in the Daz Studio Content Library to cut-and-paste them to new locations the metadata will be preserved.
Not in my experience. Has this behaviour changed since v4.12?
I must admit I haven't tried for ages, it used to work.
Sort of embarrassing.. Seems so obvious once someone points it out. Right click, cut & paste quite easy.
Not sure what meta-data actually means. (Data about data?) Was able to assign category and then "Show in Smart Content"
reboot
Wallah! There's my subsets for "Actor_ Alex8_Altern" and "Props_AlsaceMisc01"
(Test done in DS 4.12 btw. Still learning my way around in 4.16 /G8.1)
Thanks, both of you, for helping me out.
