Making an eyebrow/eyelash scalp mesh deform with the parent figure mesh?
I am creating eyebrow/eyelash hair grooms right now outside of DAZ and have opted to create a 'scalp' mesh so the underlying figure topology can be changed in the future without breaking the groom (see attachement). It is a seperate mesh that I wish to import into DAZ sans groom. I need this mesh to deform with the brow/forehead during posing so on export the parent mesh and scalp mesh are nearly indistinguishable. Is there a way to transfer the weights from the parent figure to this scalp mesh so it can deform flawlessly? Thanks!
  • margravemargrave Posts: 1,822
    It's called the "Transfer Utility". You can find it somewhere in the Edit Menu, can't remember where. After you run it and transfer the weights, add a smoothing modifier to the scalp to fix any pokethrough.
  • Edit>Figure>Transfer Utility or Edit>Object>Transfer Utility
