I can't exporter to Poser with DSON
Zoritae
Hello.
I've DS 4.7 and Poser Pro 2014
In de DS I've configured the paths with "Content Directory Manager".
I load the Genesis 2 Female (for example), select "figure base" in Mesh Resolución, after, with de "Scene" selected, in the Content Library Panel select "Create Poser Companion Files".
In this panes select "*.duf files in the current folder" and "Use this library and files extensión: figures cr2"
In the "supplement path" give new folder name.
After, star Poser Pro 2014, load the folder in Figures y can see the foder with image, etc.
Load the figure, but the view port theren't anybody.
When open Windows Explorer can see that archives are very small, DSON=64 Kb, Cr2= 1 Kb and PY=1 Kb.
With Genesis2, Poser Pro give a error mesagge: "SystemError: NULL result without error in PyObject_Call"
What doing bad?
Thank and sorry for my bad englis.
I'm pretty sure the problem is that the folder you installed Genesis 2 female Starter Essentials to isn't selected as a library folder in Poser - without that the importer won't find the geometry and so won't load the figure.
Ok, Thank so much!!!
I made is the next: in Poser Pro, in panel "Figures" add a new folder selecting "Public Document - My Library Daz3d - Runtime"... and everything worked!!!
Only, that now, Poser open dialog window answering where is the "Subnull.obj".
Well, now I can export Figures Daz3d to Max 2015
Redgards.
