Favorites icons missing
Hi,
I have a tiny problem. I copyed daz library from one drive to another, I kept both libraries, but today I removed the drive with inactive library, and lo and behold saved favorites no longer have icons on the left side of the entry, which is a problem because I can't know what favorite does what by a glance, I have to read and often don't remember what said favorite does. ( Favorites added after I copied the library to another drive have icons ) Can I correct this so that icon does appear beside the favorite entry. Thanks for answers.
Have a nice day,
Vudriga
What do you mean by favourites icon? Is this using an external add-on?
When you add something to favorites in the menu, you get that little icon on the lift side in the favorites, say you add a pose in your favorites, you will see a little square picture. Those are missing.
That is an add-on, not default Daz Studuo behaviour (unless I have missed it). I suspect it may be using the group feature, which is stored separately from cotnent 9and then relies on the database for membership records).
Ah, are you using the favourites menu rather than the Scripts menu when you right-click in a content pane and choose Create Custom Action... ? That records the absolute path of the associated asset icon in the custom action definition (i.e., %AppData%/DAZ 3D/Studio4/customactions.dsx).
