editing g8f for morph
VicS
Im editing the foot but when i put g8 into base res the skin is poking through the shoe (the foot has been previously edited), - is it ok to make edits for g8 in hires instead of base res? otherwise I fear that if the foot is edited in base res when it is put into hi res it will become thinner than the shoe
Morphs have to be made for the base resolution.
Only authorised PAs have access to high resolution morphs, us mere mortals only have access to base resolution.
Bes
You can edit it in HD, but you can't use Morph Loader Pro to turn it into a morph. You can use it's HD version as a static prop.
