Resource Error Message!
Hi, So long story short, I was having pc problems (And still do, Just not as much as before.) so after re-installing windows I had to re-install Daz again, but when I go into Daz Studio it comes up with an error message saying that the package stuff I bought wont be availible until I fix some sort of connection issue. I got no idea how to fix this, If anyone can help me, that would be amazing thanks!
  • You can load your content, though the Content Library pane under Daz Studio Formats and/or Poser Formats. Some features will, however, not work correctly without database access.
    The obvious first question is do you have PostgreSQL installed? If you do is it showing in the list of background processes after starting Daz Studio (task manager with More Details enabled)? What security software are you using?
  • Hi Shaun,
    Assuming you have tried restarting your machine...
    And assuming you used DIM to install Daz Studio (Sorry can't help with Daz Central) you need to ensure 'PostgreSQL CMS' is installed, see first attachment.
    Then you need to confirm it is running using Task Manager, see the second attachment, (don't worry if there are multiple copies of it running)
    After that you could try temporarily disabling you anti virus software.
    Best Wishes and Seasons Greeting.
    Steve.
    480 x 35 - 10K
    310 x 32 - 10K
    Hey Richard,
    I do not know how to install PostgreSQL. I didn't see a download button for that in Daz Central (Which is where I Installed Daz Studio)... If I need to do that, can you please leave me a URL or a step by step guide on how to do it? I have no idea where to look for it or anything... Thanks!
  • DryreLDryreL Posts: 30
    Same problem here. And I installed PostgreSQL in DAZ Install Manager. Any solution?
  • Richard HaseltineRichard Haseltine Posts: 111,467
    So you installed a version of PostgreSQL (which?) through Install manager and now Daz Studio is popping up the alert shwon in the opening post? Which operating system areyou using, and what security software are you using?
