NOW AVAILABLE: LNA Tokyo [Commercial]
luthbellinaluthbellina Posts: 64
edited November 2014 in Daz PA Commercial Products
LNA Tokyo is the first addition to the LNA winter collection. It includes a sophisticated coat, booties and beret with including an HD hair. Presented in nine different and mixable texture sets for clothes, and several color sets for accessories and hair. It also includes fur setup add-ons to add fiber detail to the clothes.
I hope you like it!!!!:)
Hugs
Cris
http://www.daz3d.com/lna-tokyo-for-genesis-2-female-s
Post edited by Chohole on
  • SimonJMSimonJM Posts: 6,072
    Looks nice - had to grab it :)
  • luthbellinaluthbellina Posts: 64
    Thank you!!!:)
  • Richard HaseltineRichard Haseltine Posts: 108,593
    I love the top of the coat and the beret, is there a way to flatten the skirt of the coat down so it hangs straight from her hips?
    Thanks!!!You can hide the material for de skirt and top to hide in your renders. :)
  • RenpatsuRenpatsu Posts: 828
    Really love your style - I guess it runs in the family :)
    This was really no question to have it end up in the cart :)
    OK, thanks.
    Thanks honey!!!!!:)
  • almahiedraalmahiedra Posts: 1,366
    Ohhhhh!!!! a woman coat with perfect shoulders!!! and stiches in texture "como Dios manda" perfects too. T_T I can't get dollars until 2015, it is the only reason because I don't buy this inmediately. I envy deeply anyone who could buy it.
    Post edited by almahiedra on
    I think there may be an errant vertex in the mesh of the fur add-on for the coat, if you select the Cfur surface you can see a V from the main coat/fur to a spot between the feet of the G2F figure.
    Yep, we checked and found it. It doesn´t appear in renders nor visible in the viewports. As you say, it may be a missing vertex. it´s quite weird, because I followed the same techinque in the hat too, and it doesn´t appear in the hat.
    Anyways, it doesn´t seem to cause any kind of trouble when posing or rendering. If you find any inconvenience on it when working with this set, please, let me know and I´ll find a sollution for you
    Hugs
    Thank you very much, you're very kind! :)
    Hugs
    As you say it does not appear to be an actual issue at render-time, so no worry on that score! I was a little more concerned with my mostly disappearing G2F when I load bits of LNA Tokyo! But that seems to happen with other thing too! ;)
    Hugs
    make sure you have selected the coat instead of G2M before you load the fur set. If not, you have it previously loaded, you can conform it to the coat :)
    The issue with G2F 'fading in and out' continues - I thought a reboot of the PC had fixed it, but then it snuck back in .. so I cheated! When it happened I duplicated the node on G2F and made the original hidden in scene! ;)
    1200 x 1200 - 641K
  • MuzeMuze Posts: 182
    Oooh that's so pretty!
    I love this image!!!!I like how looks it with the stockings!!!!!
    Thanks love!!!!!!:)
    edited December 2014
    Not hard to make it look good! :) And yes, stockings .. I'm a man ;) And yes, she does look good in all of her outfit!
    @Muze: thanks, I quite like it myself :)
    Post edited by SimonJM on
