Pre-loaded models are coming out "Square"
TecboyTecboy Posts: 0
When I load the pre-loaded models in the software package, they appear "square" ( file attached). My question is, my path directory reading the information wrong here or something? How do I resolve this issue? Any help would be very grateful, so I can continue to do create with this powerful tool!
Thanks in advance! :bug:
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,580
    it can be the paths messed up or maybe viewport set to solid bounding box
  • Richard HaseltineRichard Haseltine Posts: 109,474
    Make sure the folder you installed to is a DAZ Studio Content Directory in DAZ Studio - it should appear as a top-level folder under DAZ Studio Formats in the Content Library.
  • TecboyTecboy Posts: 0
    it can be the paths messed up or maybe view port set to solid bounding box
    Much appreciated "wendy♥catz"! but wasn't the solution. that just gave me different view variations to the model, which appeared as "SQUARE" model. I will do a screen shot to better explain.
  • fixmypcmikefixmypcmike Posts: 19,709
    Are you installing with DAZ Install Manager, or manually extracting the zips?
    Thank you @Richard Haseltine! Found it!
    1131 x 817 - 134K
