DS 4.16.0.3 multiple instances running [Solved]
Is it possible to run multiple instances of DS 4.16? I could definitely have 3-4 windows open in 4.10, but I just can't find a way to do that with 4.16.
Post edited by rattlefinger_4ba732f271 on
You can have multiple instances running, but the way to do it changed in 4.12.
see here: https://www.daz3d.com/forums/discussion/comment/5755421/#Comment_5755421
Aaaaaand... it works! You're a lifesaver
Thank you!
you can run newer ones like 415 and still have 412 open multiple windows.
I have a copy of the daz folder with the 412 that I copied to another drive before updating the Cdrive.
I have shortcut on dt for both versions.
And before I try 416 I'll drag 415 (and the folder off to another drive) so I can run it from there if 416 isn't happy with my system.
